07 headlight problem?
Old Jul 14, 2009 | 07:43 PM
icycook2
Default 07 headlight problem?
I have a problem with my headlight low beam on the drivers side. So the bulb isn't blown because If I mess with it for a second it will come on. It stays on for the entire time I'm driving, then when I turn it off then turn it back on later the light doesn't work again. So I do the process over again of messing with it and same result. I don't think this is a wire problem because when it turns back on it almost seems like it clicks back into the opening. but maybe I'm wrong. can someone please help? thanks
Old Jul 14, 2009 | 09:04 PM
finch13's Avatar
Unplug the harness from the bulb and see if the wires are loose. If they are, try to reseat them, if they aren't you could try using contact cleaner and some electrical grease. Both can be found at an auto parts store, the grease is usually at the counter in one time use packets for $1.
lyle
Jun 4, 2008 12:36 PM
Equalizer
Oct 24, 2007 08:11 PM
jbl2bgone
Mar 6, 2007 01:04 AM
96accord
May 15, 2006 11:35 PM
