17 master window control question
Old Nov 10, 2021 | 12:25 PM
SovietKidd's Avatar
Default 17 master window control question
I am curious are you able to swap out Individual buttons on the unit? I want to have my passenger window be automatic as well. Is that something I can do myself or does it require a lot of work, if anyone has suggestions or knowledge on this I’d appreciate it thank you
Old Nov 10, 2021 | 06:52 PM
The switch doesn't directly command the window to auto open/close. When you hit the switch to auto, it sends a signal to the driver's MICU (computer) and the computer tells the window motor to auto open/close.
Replacing the passenger window with an auto switch will not auto open/close the window, because the MICU isn't wired or programmed for this function. I'm sure it could be done, but it would be much more complicated than swapping the switch. Also swapping the switch may not be simple either.
Jon Gees
Jun 27, 2021 02:47 PM
Analyzethis
Mar 22, 2014 09:48 AM
smgray
Sep 7, 2013 07:53 PM
RobJL94
Aug 14, 2012 06:56 AM
imthehink
Dec 27, 2008 10:00 PM
