1994 accord ex transmission issue?
Old May 30, 2012 | 12:37 PM
kevmoney265's Avatar
Default 1994 accord ex transmission issue?
ok so i bought a 1994 honda accord ex off a friend of mine. he said the trans was no good it only goes in reverse so i thought ok ill have it replaced the car is really clean and that was the only problem so i have it towed to my house and it sat for a few weeks i changed the battery and now it will go in drive but it takes a few seconds before it catches? like maybe 5-8 seconds? i drove it around the block a few times and after a few trips around it seems to not move that well anymore? i asked a few people what it could be? some say the at computer some say they shift solinoids? i wanna know what it could be before i just get a trans? i dont wanna put money for something i might not need!!! any help would be apprecitaed thanks!
Old May 30, 2012 | 12:49 PM
Check the fluid level first.
Is the D4 light flashing? If it is flashing at times, try to retrieve any trouble code(s) by jumping the blue service connector with a small paper clip or wire, that is located under the passenger side dash. There is info. regarding this at the sticky up top of this forum.
Generally, the 5th generation Accords (94-97) automatic transmission were pretty good. They didn't fail that often if properly maintained. My previous 95 Accord went 300,000 miles without any problem and it is still going after I gave the car to my nephew. The TCU was not really an issue on most of them. They can fail due to running with low fluid levels which may be due to slow leaks at the axle seal, or not changing the fluid regularly, etc. Most of the ones I hear about with transmission problems required replacement or rebuild.
Old May 30, 2012 | 04:13 PM
just checked the fluid it full i can actually see thats its full when i remove the dipstick on the ip stick an din the trans itself? no blinking d4 either? shoul i just replace the whole trans?
Old May 30, 2012 | 05:03 PM
Does the D4 bulb even light up under normal conditions? Just asking to to see if the bulb was blown. If the bulb is okay, try jumping the blue connector anyways to see if it flashes out any trouble code.
It may end up being the transmission. You sometimes can find relatively good used transmission for a couple hundred at salvage yards, etc. One of my buddy mechanics either finds good used ones or he rebuilds them himself.
Old May 31, 2012 | 12:41 AM
Yea if i put it in d4 it lights up??? Gonna swap the shift solenoids maybe they are bad?
Old May 31, 2012 | 07:57 AM
Roader's Avatar
A good page on troubleshooting Honda automatics:
"http://techauto.awardspace.com/transmission.html#troubleshooting"
Old May 31, 2012 | 08:24 AM
Dsalzano94's Avatar
Hi I'm having a similar issues I bought car from some jerkoff trans is jumpy since I bought it changed headers down pipe exhaust intake I have the f22b1 Sohc it's should be a lot faster way to slow last night I cleaned solinoides and put new fluid in the trans it ran better then this morning I started it stalled 2 times 3rd started check engine light is on steady and d4 blinks prior to cleaning up trans check engine light came on and off I'm still running the stock cat need some help
Old May 31, 2012 | 06:35 PM
Dsalzano94 - Start you own thread, so this one is not as confusing. I would check for engine and transmission codes. In the common diy thread on top of the gen tech help forum, you can open a link to checking engine codes.
Maria Penguini
Jul 15, 2014 10:39 PM
t_lar
Jan 22, 2013 07:19 PM
BSmoov83
Jan 2, 2013 06:41 PM
silentscream
Oct 11, 2011 08:48 PM
baldjbb
Apr 25, 2011 10:56 PM
