1995 Honda Accord Lx
Old Jan 2, 2024 | 08:52 AM
aaron miller's Avatar
Default 1995 Honda Accord Lx
Hey y’all I have a 95 accord with the f22b1 I have spark and fuel pulled the plugs and the where soaked I put a new coil in the distributor and it has brand new plugs and wires and fuel pump it started a couple days ago and went down the road and died again it’s been sitting for a month and a half because I can’t figure out the problem I have signal from ecm to the distributor and it’s getting all the way thru it to the plugs just very weak spark any ideas of what it could be?
Old Jan 3, 2024 | 12:34 AM
You can check for obd1 codes using the write-up in the common diy section on top of the gen tech forum.
The ignitor inside the distributor could be bad or the distributor cap and rotor could be making or contact. A bad ignitor aka icm should set a code. A corroded or poor connection inside the distributor might also cause this behavior.
Kms
Nov 28, 2023 11:34 AM
Caleb Wilson
Nov 8, 2014 09:02 AM
ghostynoises
Mar 7, 2014 02:22 PM
Prozon
Oct 10, 2010 10:56 PM
iniguy
Sep 8, 2009 08:27 AM
