1996 Accord - Distributor Leaking Oil Onto Transmission - Causing Slippage?
Old Jun 21, 2013 | 11:35 AM
Neptun3's Avatar
Default 1996 Accord - Distributor Leaking Oil Onto Transmission - Causing Slippage?
When I drive my 1996 Honda Accord the transmission slips or shifts hard when changing gears. I am not sure what the problem may be but about a month ago I had a bad distributor that was leaking oil onto the transmission. Can this cause problems for the transmission? I have replaced it with a new distributor but the transmission still slips or shifts hard. Would I just need to do a transmission fluid change/flush?
Old Jun 21, 2013 | 11:57 AM
shipo's Avatar
If you have a 5-Speed and oil found it's way down into the clutch assembly, then yes, slippage can occur, however, if you have an automatic then your transmission is suspect.
Old Jun 21, 2013 | 01:21 PM
Neptun3's Avatar
It's an automatic transmission. I'd say it slips probably half the time and sometimes it's barely noticeable. I don't want to do further damage and want the slipping to be gone so that is why I'm seeking a solution.
Old Jun 21, 2013 | 02:02 PM
shipo's Avatar
How long since the transmission fluid has been changed?
Old Jun 21, 2013 | 02:12 PM
Neptun3's Avatar
I'm not sure cause I bought the car used. When I check the transmission dipstick the oil is a very dark brown color.
Old Jun 21, 2013 | 02:26 PM
shipo's Avatar
Change it now, change it next weekend, and change it again the weekend after. Doing that may allow you to get a few more miles out of the tranny, but at this point, nothing is a guarantee.
Old Jun 22, 2013 | 07:53 AM
While changing the trans fluid - BTW I highly suggest using Honda Trans fluid - check the throttle control cable (this runs from the TB to the trans) for proper adjustment and movement.
Old Jun 22, 2013 | 09:44 AM
MysticBlueEX's Avatar
Almost A Senior Member
I wouldn't rule out that if external trans components get dirty or oily that it might be the source of the problem. I had an instance for several days that my trans wouldn't shift. It hung up and didn't shift out of second and third, up until 4500+ RPM. I thought the trans was blown out. I even called around for estimates.
At the time, the coolant was leaking onto the connectors on the shift solenoids.
I got the coolant leak fixed at the dealer for 1/2 hr labor ($48) and the trans has been wonderful ever since.
But please drain/fill the fluid with Honda fluid. I have been getting mine done every 20k miles or so.
Attached Thumbnails 1996 Accord - Distributor Leaking Oil Onto Transmission - Causing Slippage?-dscf1442.jpg
letsclique
Feb 16, 2013 10:11 PM
Andrew7048
Oct 7, 2012 12:12 PM
BlackHoleAccord
Jul 11, 2012 12:35 AM
dhenry
Jun 25, 2012 10:41 AM
Vancefish
May 2, 2008 09:48 AM
