1996 trans doesn't like to shift anymore. :(
Old Dec 17, 2010 | 12:07 PM
Its a problem with that sensor, or the wiring. The next step is to unplug the PCM, and test the resistance between B14 and B15 with the sensor plugged in. The reading should be the same as your first resistance reading.
Attached Thumbnails 1996 trans doesn't like to shift anymore. :(-pcm-connector.jpg
Old Dec 17, 2010 | 05:10 PM
I recently had a persistent code 9 (faulty CYP sensor on my 94EX. As you did I measured resistance at the sensor (800 ohms. in spec). As PA suggests, I next checked resistance at the ECU connector, and got same values. This indicated a fault in the ECU itself, which was resolved w/ a used ECU. You could have a similar problem, but a wiring fault is still possible.
Old Dec 17, 2010 | 07:49 PM
After you measure resistance at those pins at the ECU, next check whether there's any continuity to ground on either of those wires. (shouldn't be any continuity to ground)
GeL
Jul 6, 2013 01:12 PM
Accord Owner
May 30, 2011 09:23 PM
jbraly
Aug 12, 2009 02:02 PM
fishin4fun
Jul 20, 2009 07:52 AM
notamechanic
Sep 2, 2006 07:46 PM
