1997 Accord EX V6 Overheating: Diagnosis
Old Jun 30, 2010 | 12:15 PM
  #21
Coming from the split where the T-stat housing opens to install the T-stat? Or where the T-stat housing bolts to the engine?
Old Jun 30, 2010 | 12:50 PM
  #22
brent97accord's Avatar
looks like its coming from where i opened the housing to put in the new t-stat.
Old Jun 30, 2010 | 08:50 PM
  #23
deserthonda's Avatar
i wonder if the t-stat slipped down when you were installing it and did not sit properly in the housing , thus it would cause a leak ,,,,,,,,t-stat came with new gasket ,,, right ?? did you use a Honda t-stat??
Old Jun 30, 2010 | 10:15 PM
  #24
The T-stat gasket is split around the inside, & the edge of the T-stat goes into that split. That way the gasket covers both sides of the T-stat and seals against both sides of the housing. Is it possible you put the gasket on only one side?
Old Jul 1, 2010 | 02:34 PM
  #25
I did put the t-stat inbetween the slits in the gasket. However, it may have slid down during install.
Also,
I used the old gasket and an aftermarket t-stat ( i know, i know)
Good news, I ordered a honda t-stat w/ gasket, installing very soon.
Old Jul 1, 2010 | 03:19 PM
  #26
Wicked Pete's Avatar
I'm kinda waiting to see what's up. Mine was getting hot, not like yours though. Let us know.
Old Aug 2, 2010 | 01:40 PM
  #27
fbodyrs96's Avatar
me 2, my 96 over heats when in stop go traffic only if the AC is on.
Old Aug 2, 2010 | 06:13 PM
  #28
"FBODYRS96"- Your issue sounds different. Only in stop and go traffic with the ac on? When the AC is on are BOTH fans running. With the AC off, sitting still, do the fans cycle on and off as the car warms up?
Old Aug 3, 2010 | 09:28 AM
  #29
fbodyrs96's Avatar
yes, both fans are coming on and off. we had the same problem last yr, then it blew the upper rad hose, affter it was replaced it started working right again.
Old Aug 3, 2010 | 10:54 AM
  #30
my issue was the coolant level being very low. eventually got that way from a small leak.
only on highway driving was there enough air to keep the motor cool.
Jennifer Wheeler
Feb 1, 2012 06:41 PM
JB79
Aug 28, 2011 08:53 AM
tbrower
Aug 25, 2010 07:57 PM
goldentrail
Dec 23, 2009 01:46 PM
Notpretty
Jul 22, 2007 09:42 AM
