1997 accord lx fans not working
Old Feb 19, 2012 | 03:58 PM
  #31
Keep a close eye on the coolant level. Remove the radiator cap and check the level when the engine is cold. If you have to keep adding fluid, then you likely have a leak somewhere.
Some parts stores have a radiator pressure tester that they load out. You will pay a deposit and get the money back when you return the tester. Call the parts store before you go, because some stores do not have them. The radiator should be able to hold about 16 psi for a long time (>15 minutes).
Old Feb 19, 2012 | 07:23 PM
  #32
Another good reason for doing that, is when it's running (hot) the leaking coolant evaporates right away. When you pressurize it cold it can help you find the leak.
barneypoo69
Jul 9, 2012 12:53 PM
Golddoor
Aug 17, 2011 05:10 PM
americapitalpaul
Jul 17, 2011 01:32 PM
stephenml
Nov 2, 2009 09:55 AM
SteveZ
Jan 5, 2008 05:08 PM
