1997 accord overheating
Thanks for the good advice.
It's done, nephew managed to get the hose from below the distributor. Angled long needle-nose from the front (clamp was pointed straight forward).
Hose looked like it had a golf ball in the end of it (and split).
Nothing like having a trained mechanic in the family!
Be sure to have your bleeder valve open when filling up your coolant until you have a solid flow of coolant coming out.
My experience is that the heater hose goes bad faster when contacting with engine oil.
Yes, hence why I like to replace that dist o-ring when that hose is showing signs of "swelling". The oil will leak onto that hose allowing it to "go bad" faster. A "swell" right where it connects to the connector on the head is usually a sign the dist o-ring is leaking oil.
