1999 Accord Brakes Sticking
Old Sep 11, 2014 | 07:07 PM
Bama's Avatar
Default 1999 Accord Brakes Sticking
My V6 Accord front passenger side brake is sticking when the car gets up to operating temperature about 10 minutes of driving. I replaced caliper, hose, and pads. Problem still remains. And when I say sticking its not just a little dragging, it will stop the car when I let off the gas. Eventually will not move. Please help if you have ever heard of this issue
Old Sep 11, 2014 | 07:53 PM
When brake is stuck, crack open the bleeder and see if fluid is forcefully ejected.
If not, then a mechanical problem is causing the sticking, suspect caliper pins not installed correctly and/or inadequate lube.
If fluid is ejected, something is trapping pressure in the pax side brake line, perhaps a bit of debris. It might be helpful to do a pump/release bleeding to hopefully eject the plug.
Since problem only affects one wheel, the master cylinder is not the problem.
Old Sep 11, 2014 | 08:04 PM
Bama's Avatar
I will do the bleeding again I can't remember how much pressure it had when it was stuck. Today after putting the new caliper on when I bled the brakes with pedal pump fluid would spray fender wells
Old Sep 12, 2014 | 08:50 AM
If caliper held pressure w/o foot pressure on brake pedal something is trapping fluid in the caliper. It would be normal for brake fluid to spray out if foot pressure is applied.
Old Sep 13, 2014 | 02:41 PM
Bama's Avatar
I took the ABS pump off blowed air through it and bled a four corners( pump and release) and so far seems to have corrected the issue. Thanks for the advice.
wifes01
Aug 17, 2011 04:16 PM
jacob23rd
May 13, 2011 01:58 PM
uhenry1
Mar 10, 2011 06:21 AM
hondaptct
Aug 12, 2009 02:45 PM
lillum111
Aug 12, 2006 02:19 PM
