2000 accord transmission issue
My daughter has a 2000 accord (170k)that has the following symptoms:
1. hard shift into second gear and sometimes will do what feels like a double shift into second gear.
2. when shifting into drive or when shifting into 1st (like at a stop sign) it will sometimes shift hard into 1st gear.
Shifts into 3rd and 4th are always fine and there is no slippage at all. Are there any things I should check (solenoids?) before assuming the transmission is on it's way out? If it is on the way out is failure imminent, or does it have a few weeks or months before it dies?
Stop by a parts store and have them scan for codes. Post the codes on here. They start with the letter P and have four numbers, like P1234.
Cleaning the shift solenoids is a good idea and may be a simple fix.
You'll get different opinions about changing the fluid on a marginal transmission. Do you know when the transmission fluid was last changed?
Bigtom2000
Oct 22, 2013 05:56 PM
