2000 EX 5MT / front end clunking/vibration
Old May 24, 2016 | 02:12 PM
Frugalhondaguy's Avatar
Default 2000 EX 5MT / front end clunking/vibration
Just turned 220K on my Accord. Began to hear some clunking about two weeks ago, and now it seems much more pronounced. Only notice the problem when I hit bumps, but today I had a BMW on my butt when I was exiting a cloverleaf off the highway and decided to leave him, which I do often. Today however, I hit a rough patch of road and the car not only made the normal "clunking" noise but the steering wheel began to vibrate. I've ordered a new strut/spring Assy, which I'll have Thursday. Hope this fixes it, I may also change the stabilizer bars/links. Can anyone make any other suggestions?
Old May 24, 2016 | 05:59 PM
Do an inspection before replacing the suspension parts that may or may not be broken. Oil leaking on the strut, broken spring, noise from the say bar, loose ball joints, tie-rod ends, etc..
Here is a good video on how to do this.
Old May 24, 2016 | 07:19 PM
Thanks PAHonda. I'll jack the car up tomorrow and see if I can find anything loose. I did the bounce test on the front and did hear some clunking, it seems to be coming from the right side. I did check the motor mounts and they look good. I'll check the cross member to make sure it is tight.
Old May 25, 2016 | 12:05 PM
Rechecked the motor mounts today and found a crack in the front mount. It looks like it's a combination of the front motor mount and the struts. I'll change out the struts/springs tomorrow and see if that helps. In the meantime, I'm ordering a new front mount.
Old May 25, 2016 | 03:44 PM
Decided to change out the front mount today. Still have the clunking, so tomorrow the struts/springs/insulator. Hopefully, we will be at peace again.
Old May 26, 2016 | 01:53 PM
Feeling like a foooool!
Received the struts today and was ready to install when I noticed that the plastic "skid plate" or whatever you call it was loose and thumping on the cross member. There were only 3 plastic pins holding it on. I removed it and took a drive. The only noises I heard was normal road noise.
Old Jun 25, 2016 | 09:44 AM
Turns out my right strut was completely blown, so I replaced both with Sensen struts. Car drives like new.
Old Jun 12, 2018 | 10:29 AM
Jet sitter's Avatar
Just an update on the Sensen struts. Now have 30K miles on the struts and they are fine.
Frugalhondaguy
Jun 12, 2014 07:57 PM
Boser1995
Feb 1, 2011 04:55 PM
Boser1995
Feb 1, 2011 04:43 PM
jaybeezi
Aug 6, 2009 07:10 PM
corr04
Jul 25, 2006 11:32 PM
