2002 Honda Accord Speed Sensor
Hi, I am installing a navigation unit and need to install the speed sensor connect. I have found that the connection should go at the ECU? Is that correct and if so can anyone tell me where that is? I have a 2002 Honda Accord 4 door EX. Thank you.
I think that the 2002 PCM is under radio, but way below the radio.
It looks like Pin C23 has the VSS signal wire.
Copy and past the link below into your browser for the Honda Tech thread.
honda-tech.com/showthread.php?t=2785965
That honda tech thread showed the connectors for your PCM. Didn't mean for you post in that forum.
I think that the PCM is as close carpet on the hump in the floor board as you can get. It is somewhere under that piece of plastic at the bottom of the picture you posted. You might not be able to access it from where the radio is installed.
blueking
Mar 24, 2013 12:31 PM
