2003 Accord LX V-6 A/C Won't Cool
Old May 3, 2012 | 05:05 PM
  #31
tkenwort99's Avatar
I did jumper the pressure switch plug to simulate a good pressure switch with the clutch relay installed no help. The only way to make the clutch engage is jumper the clutch relay itself.
Unless someone else has any ideas after all I have checked with everyone's help, it does appear the ECM/PCM is bad. Any idea what is a reasonable cost to expect from a Honda dealer?
Many thanks to all. I learned a lot.
Old May 4, 2012 | 06:28 PM
  #32
Hang on, I'm not willing to give up yet. If you are willing to do a few more things?
I'm attaching a pic. Two inputs to the relay, key on, should be hot. When the ac is turned on, another will ground, closing the relay and sending power. Test the inputs, test the relay.
Attached Thumbnails 2003 Accord LX V-6 A/C Won't Cool-7th-gen-hvac-comp-relay.jpg
Old May 4, 2012 | 07:18 PM
  #33
You can find your ECM on ebay or car-part.com. You need to get the part number from your computer and match the part number to insure no problems. I saw several w/ prices ranging from $50-$100.
Old May 5, 2012 | 07:54 AM
  #34
tkenwort99's Avatar
I will check for the voltages and ground at pin 3 later today.
Does the ECM have to be programmed for my specific car? Why do the diagrams always refer to it as ECM/PCM? Looking under the dash, it is well confusing and a little intimidating. Hate to make things worse.
Thanks again.
Old May 5, 2012 | 09:42 AM
  #35
tkenwort99's Avatar
Clutch relay voltages are good at pins 1 and 4. Still no ground on Pin 3 from the ECM. Both radiator fans and the inside fan come on with A/C on.
A/C works fine if apply 12v to Pin 2; Compressor clutch then enagages.
At this point, any guidance on ECM replacement would be much appreciated.
Old May 5, 2012 | 10:44 AM
  #36
Well, you are going to need to have the new pcm programed to your keys. Other than that, pretty much plug and play.
Old May 5, 2012 | 11:59 AM
  #37
tkenwort99's Avatar
Can only a Honda dealer program the new PCM to my keys?
Old May 5, 2012 | 12:40 PM
  #38
Unless you have a locksmith with the proper tools, which will be hard to find.
Or you're lucky and can get the "key" that is programed to the new ecu. Yes the "new" key won't work your locks but you can drive the car and make sure this solves the issue.
Old May 29, 2012 | 06:25 PM
  #39
tkenwort99's Avatar
ECM replaced at the local dealer. $800. So far so good.
Cam's Honda
Jun 21, 2011 01:15 PM
Hera
Jan 30, 2011 09:31 AM
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
jbraly
Sep 1, 2009 01:26 PM
00Accord3
Jul 31, 2009 11:15 AM
