2003 Honda Accord A/C blowing out warm.
Old Jun 28, 2014 | 11:11 PM
ses01's Avatar
Default 2003 Honda Accord A/C blowing out warm.
The A/C on my car is blowing out warm. I added A/C refrigerant enough to fill it up a month ago.It worked for a month and all of a sudden it stopped blowing out cold. It blows our air but its warm when i have it on the correct A/C settings.The car still has all of the refrigerant I put in. Its not a leak where the air refrigerant goes and I know for sure. I think it might be a fuse that is burned out. If you have any suggestions on what the problem is or if its a fuse. It would be great to know what fuse is the one responsible for the Air Conditioner. Help Please and thank you.
Old Jun 28, 2014 | 11:39 PM
1. When you turn on the A/C, does both cooling fans in the engine compartment run?
2. Check under-hood Fuse No. 12 (7.5A) to make sure the fuse for the A/C compressor clutch relay is not blown.
3. If under-hood Fuse No. 12 is okay, to do a brief test to check that the compressor runs:
a. The A/C compressor clutch relay is number 2, as shown in the attached under-hood fuse/relay box diagram.
https://www.hondaaccordforum.com/for...utch-relay-jpg
b. You would pull that relay out, then use a jumper wire where relay terminals no. 1 and no. 2 would normally be plugged into.
https://www.hondaaccordforum.com/for...king-relay-jpg
Does the compressor run? Only do the test briefly. Do not leave it this way.
rjaccord
Jun 17, 2017 12:07 PM
winterland
Oct 8, 2014 06:53 PM
Fanophins
Apr 20, 2014 03:15 AM
BHoward711
Apr 12, 2010 08:57 PM
stevemacleodns
Jun 24, 2008 09:04 AM
