Sponsored by:
Sponsored by:
2004 Honda Accord LX-Brake problems
Old 12-23-2013, 03:24 PM
Patrick Walker's Avatar
Default 2004 Honda Accord LX-Brake problems
Hello,
I have a 2004 Honda Accord LX Sedan automatic with 333, 400 miles. Yes it has alot of miles but it runs great. No maintenance or engine light on! However, I notice when I'm driving and I brake while going over a small hole or rise in the road, my brakes sort of fail; even when I get on the brakes I can tell that there is something wrong. I can hear a grinding noise when I press my brakes (on the inside of the car) and it sounds like gears grinding when you miss a gear in a manual transmission. Also when I am pressing the brakes I can feel the brake pedal jumping under my feet. Yes this is crazy and before I take it to my mechanic I wanted some insight for myself.
Thanks,
Patrick
Old 12-23-2013, 03:46 PM
Worn out pads w/ metal/metal contact is likely. Rotors are warped or worn badly due to worn pads. New pads and rotors should put things right.
It is possible something else (rocks or debris in brake pad assy) can cause noise, but this is less likely.
Old 12-23-2013, 04:22 PM
Thanks! this helps
Old 12-23-2013, 06:40 PM
Talking Hey Member **
Originally Posted by Patrick Walker
Thanks! this helps
Thanks for posting and joining the HAF..
Attached Thumbnails 2004 Honda Accord LX-Brake problems-snowdaydec14th2013-007.jpg
Old 12-24-2013, 01:48 AM
kris_loehr's Avatar
Hello,
Thanks,
Patrick
You seem to be describing the Anti Lock brakes. The pedal makes a ratcheting feeling and sound. As the tires stop the vehicle what kind of shape are they in?
Old 12-24-2013, 05:35 AM
Cool Anti lock brakes
Yes that is what everyone says...and when I stop it scares me because it takes awhile for the brakes to really kick in and stop (they are working, just struggling a bit). As far as tires go, I haven't had new front tires since 2012. Ive been buying used tires ever since. After a month or two of owning the tires my aunt always notices and says.."hey why are your tires being eatin' up in the middle," seeing that I'm no car guy I just said hmmm I dont know. Maybe it has to do with alignment issues, or something else I really dont know. Another guy on the other Honda accord website said worn out rotors and calibers but guess we will see when I take it to the mechanic tomorrow!
Old 12-24-2013, 07:37 AM
EXV6NIGHTHAWK's Avatar
Bad speed sensor, on one wheel, causing the ABS to activate? Could be a lot of things causing the pulsing sensation, but I would check the pads, and the calipers for leakage and free movement first. If brake fluid gets on the pads it can cause them to jump when the brakes are applied. Good luck with it.
Old 12-24-2013, 11:14 AM
Default ABS engaging
Thanks everyone! found out that it was my ABS system engaging when I go over bumps and rises and try braking! Due to low traction this caused ABS to kick in.
Jouannyr
03-02-2012 06:32 AM
snowice
02-20-2012 09:57 PM
Chirobc
07-05-2011 05:36 PM
djdaveq
08-31-2007 11:10 PM
KimberlyC
04-16-2006 11:51 AM
Quick Reply: 2004 Honda Accord LX-Brake problems
