2007 V6 - Noise on startup
Old May 30, 2018 | 04:21 PM
Edem's Avatar
Default 2007 V6 - Noise on startup
My honda accord 2007 v6 engine makes loud noise at a cold start up and it becoming worse by the day
please i need help
Old May 31, 2018 | 06:29 AM
This doesn't have anything to do with wheels & tires so I'm moving it to General Tech.
Can you give any further description of the sound? Does it fail to start? Does the sound go away as it warms up? Goes away gradually or suddenly?
Old May 31, 2018 | 12:25 PM
Edem's Avatar
Default Engine noise
yes the noise gose off when the engine warm up
Old May 31, 2018 | 02:13 PM
shipo's Avatar
A few questions:
  • How many miles on the engine?
  • Have you had the valves adjusted?
  • What is the oil level in your engine?
  • How long since you've changed your oil?
  • What kind and grade of oil are you using?
Old May 31, 2018 | 02:20 PM
Edem's Avatar
Originally Posted by shipo
A few questions:
How many miles on the engine? =13,0000
* Have you had the valves adjusted? = no pls
* What is the oil level in your engine? = normal level
* How long since you've changed your oil? = just last week
* What kind and grade of oil are you using? =SAE 20W-50
Old May 31, 2018 | 02:40 PM
shipo's Avatar
Yikes! You're running 20W-50 oil in a 2007 V6 Honda engine? Get that stuff out of there now! Change to something like a 0W-20 and I'm guessing your start-up noise will be gone.
Old Jun 5, 2018 | 10:24 PM
EXV6NIGHTHAWK's Avatar
Without a sound clip or video it's tuff, but I'm guessing timing belt tensioner rattle. Has the timing belt (and tensioner) been changed? My 03 V6 would make the rattle sound on first cold start up. The sound would fade quickly as the engine warmed up. I changed the timing belt, tensioner, water pump, both pulleys, and coolant, and the noise was gone.
I'm hoping the 20w-50 was a type-o or something. I used the required 5w-20 in the 03.
techpro87
Oct 26, 2014 11:36 AM
Hangfire79
Mar 31, 2013 10:58 AM
ufosearch
Mar 2, 2009 10:59 AM
gaugeman
Mar 10, 2008 01:30 PM
farango
Feb 11, 2008 08:12 PM
