2012 Accord Hard Start and Engine Light On
Old Apr 15, 2026 | 09:33 AM
draser01's Avatar
Default 2012 Accord Hard Start and Engine Light On
Hey guys,
So recently I noticed that it takes several attempts to start the car (2-3 tries) and engine and traction control lights are on. Reading the codes I get a P062F and a 83-11 codes.
Below is a list of what I've done so far:
1 - replaced battery, old one was 6yrs old and not holding charge one day to the next. Measured 14.4V across battery with engine running.
2 - cleaned negative battery strap, as I was having some contact resistance to the chassis.
3 - measured ECM grounds, battery voltage and 5V supply.
4 - measured CAN wires resistance from ABS to ECM, battery voltage and ground at ABS module.
The freeze frames associated to the codes above show some questionable (to me) parameter statuses:
For code P062F:
F Injector
0.00ms
I read this as no pulse at fuel injectors, hence no start.
For code 83-11:
INHIBIT FLAG STATUS FROM PCM
INHIBITED
COMMU_PCM (COMMUNICATION STATUS)
Failed
On the last one, since all other communication statuses show "Normal" I'm reading this as failed/no communication between ABS and PCM modules.
I wanted to test the ABS module (raise the wheel and activate ABS) as the next step, to see if the failed PCM comms above is indeed true.
Any ideas on how to tackle this further, it seems I am dancing around the issue here?
Old Apr 16, 2026 | 11:30 AM
draser01's Avatar
Anyone?
skramer360
Jul 11, 2022 02:43 PM
93Accord2.2
Nov 7, 2013 07:10 AM
fvansan
Aug 17, 2013 10:56 AM
LeftyJR
Dec 19, 2008 09:50 AM
venks
Jun 23, 2007 08:39 PM
