84 Accord Starts then dies
Old Sep 4, 2010 | 06:03 PM
barnfindhonda's Avatar
Default 84 Accord Starts then dies
I am back for some more assistance! I bought an 84 Accord not running. The car sat for almost two years.
Replaced the following:
Timing Belt
Coil
Plugs
Plug Wires
Cap and Rotor
Fuel Filter
Fuel pump
Oil and Oil filter
Checked the following:
Wires to Coil ok
wires to and ignitor in distributor ok
Spark to plugs ok
Compression ok
Car started and idled ok and I drove it for 10 miles and it ran great. Now a week later, went to drive it again and now it will start, idle for 1-2 seconds and die. If I feather the gas pedal I can keep the engine running although tough to keep running, but the minute I take my foot off it idles for a second then dies.
Any ideas?
Old Sep 4, 2010 | 10:44 PM
Corrosion inside the gas tank? Sediment & rust picked up & plugged the fuel filter?
Old Sep 5, 2010 | 10:04 AM
I have replaced the secondary fuel filter (the one next to the gas tank) two times already.
Old Sep 5, 2010 | 10:57 AM
Sorry for all of the questions, trying to understand more.
On 3rd gen (86-89) they have two fuel filters. One in the back behind the drivers rear tire and the other under the hood.
I'm sure you looked but is there a vaccum leak (base gasket, vac line/hose). Or does it seem like it's flooding. Does it do this all the time or just when cold. Added fresh gas.
Old Sep 7, 2010 | 10:51 AM
Pooman212
I have checked the primary fuel filter (next to the carb). Does not appear to be flooding.
As for the vaccum leak, I keep checking all of the vaccum lines and have not found a leak. I have tried spraying carb cleaner around the carb while starting and have not noticed any difference.
Gasoline- I am pretty sure the tank was dry when I bought the car. I have put new gas in the tank and replaced the secondary fuel filter two times aready.
The car starts, idles for 1-2 seconds and dies.
Old Sep 7, 2010 | 07:06 PM
Sorry, I'm tstll rying to figure out if it is starving or flooding, as I'm sure you are so:
Sat for two years-could the float level, needle/seat be stuck. 86-89 have a sight glass on the drivers side of car. Had an 81 but can't remember. When it dies does it restart right away.
If you feather the gas until warm, does the same issue happen (choke).
Hondadude (?-bosiehonda)- carb bowl vent valve? Proper flow and psi from the pump-carb, so psi is 4~6 but volume could be an issue.
At this point I'm sorry I only have more suggestions/ideas than answers.
Old Sep 8, 2010 | 10:35 AM
Hi poorman212,
Thank you for your responses. It is helpful.
When the car dies, I step on the gas one pump and it restarts right away, runs for 1-2 seconds then dies. It is very difficult to keep the engine running by feathering the gas, inconsistant idle and the moment I take my foot of the gas it dies.
I will look for the sight glass and read up a bit more on the carb.
Old Sep 8, 2010 | 10:50 AM
deserthonda's Avatar
at the back of carb there is the idle solenoid,,,,,,,,make sure that you hear ( feel ) it clicking when key is turned on,, if it clicks, remove it ( need an 8 mm wrench ) and spray carb cleaner inside the port and blow it with compressed air, put back together ..
do not lose the little o-ring ..
Old Sep 17, 2010 | 04:00 PM
Just a follow up. The Honda is alive and well! For those who are interested, the problem was carb related. The fuel cut off solenoid on the side of the carb was stuck, not completely open or shut. My mechanic recommended bypassing the solenoid. That did the trick!
Thanks for all of the help.
Old Sep 17, 2010 | 07:07 PM
Thank you for reporting the "fix". Enjoy the ride.
tater1972
Jan 18, 2020 01:16 AM
mgharter
Mar 7, 2011 07:13 PM
mawdy
Jul 20, 2010 12:01 PM
HondaAccord93
Jul 18, 2010 03:37 PM
zx6r98
Sep 10, 2009 03:34 PM
