90 Accord EX Hot Start Issue
Old May 11, 2013 | 01:30 PM
seerail64's Avatar
Default 90 Accord EX Hot Start Issue
I have 90 Accord EX...... replaced water pump, timing belt, crankshaft/camshaft seals 6 weeks ago. Having starting issues when hot, installed new fuel relay which I was assured was source of problem... did same thing last night. This morning was difficult to start which was odd. Also seem to still be having water loss issue, few drops under car but nothing in oil or vice versa...
Old May 11, 2013 | 07:58 PM
Read posting rules and follow them in future.
Suggest listening carefully for fuel pump in fuel tank to come on when keyswitch is turned to On, run for 2-3 secs, and cut off.
If you hear the fuel pump, when hard/no start occurs, then spark is likely the problem.
If you don't hear the fuel pump, then fuel pump may be sticking, or you were sold a bad main fuel relay (unlikely).
Old May 13, 2013 | 11:40 AM
seerail64's Avatar
Relay was brand new, I work for dismantler, the previous owner of car actually came by my shop and told me what he had purchased for the Accord I got it from... my old relay actually had heat warp on housing, you could see gap on plug side.
I'm inside now, will listen for fuel pump and keep you posted...Thanks for info!
Mr500CM
Jun 6, 2014 07:42 AM
jacobcakes
Mar 24, 2014 02:01 PM
gasface11
Jul 11, 2012 12:33 PM
bpethomas
Jun 5, 2012 10:47 AM
Mcgill224
Jul 12, 2007 11:27 AM
