90 accord lx dieng problem
Old Apr 3, 2012 | 10:37 PM
Josh McClure's Avatar
Exclamation 90 accord lx dieng problem
i have a 90 honda accord lx 2.2 4cl 16 v . with an f22a1 motor and an AT tranny
for the past month it will run fine until randomly dies out of nowhere and sometimes on the highway. and after i sit for a few mins it will restart but then die on the take off , or dies when ive gotten up to speed for about ten seconds
ive read the codes and its throwing code 15 which is the ignition output signal . ive replaced the tps, vss, main relay , and also has a new distributer with new wires and plugs
ive read on here that its the ignition modual but i dont see how with a new ditributer in place
if someone can please help , please give me advice im desprate to know whats goin on ive put way to much money in this car to let it go
Old Apr 3, 2012 | 10:42 PM
Did the new distributor come with a new ignition module?
Old Apr 3, 2012 | 10:43 PM
yes it did . the whole thing was new
Old Apr 3, 2012 | 11:03 PM
When the engine is running, try shaking the key. Does the engine stall out?
There is a ground wire bolted to the thermostat housing that is important. I would unbolt it and clean the bolt and eyelet with a wire brush.
Old Apr 4, 2012 | 07:17 PM
no the it doesnt stall when i wiggle the key . and i cleaned it off but didnt it again today
Old Apr 6, 2012 | 03:32 PM
Sorry, I'm confused.
Is the car still acting up?
Are you getting the same code?
Did you clear the code?
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
