91 Accord Dashlights + runninglights problem
Old Jan 9, 2010 | 02:34 PM
tomejandric's Avatar
Unhappy 91 Accord Dashlights + runninglights problem
When I turn on my lights the dashboard lights do not come on nor do my rear running lights.
After awhile they will come on. I tried the fuses, and the dimmer. When i fiddle with the light switch (rotating back and forth between the parking lights and the running lights mode on the column) they come on.
Is that a tricky fix?
I assume it's a faulty switch at the column. I'm not sure how difficult it is to replace, assuming that is the problem.
Thanks Jim and whoever
Last edited by tomejandric; Jan 11, 2010 at 01:44 PM. Reason: more information around the disfunction.
Old Jan 11, 2010 | 07:01 AM
Fuses?
I don't know the wiring for 1991, but check in the DIY section for a sticky thread about repair manuals.
Old Jan 11, 2010 | 01:45 PM
Thanks, I added some more information that might be useful.
Old Jan 11, 2010 | 02:25 PM
Yeah, what you added about wiggling the switch really makes it sound like a bad switch.
The switch #14 looks like it's not too hard to swap out. Not sure what it takes to remove the steering column plastic trim covers. That switch is kinda pricey, so I don't know if it's worthwhile to try dismantling it???
NPaccord
Dec 7, 2014 05:36 PM
trouble
Aug 21, 2012 07:46 PM
Cody_754
Dec 22, 2011 12:39 AM
kellysa111
May 1, 2009 08:35 AM
92Inspire
Aug 13, 2006 03:37 PM
