91 accord ec problems Please help
Old Jan 13, 2008 | 03:58 PM
HondatechAV6's Avatar
Default RE: 91 accord ec problems Please help
if there was oil on the spark plug boots it is indeed from a leaking valve train spark plug tube seal or valve cover spark plug tube seal leaking. when you remove the plug the oil drained into the combustion chamber and in the process wet up the plugs.
Old Jan 13, 2008 | 04:28 PM
co1388
Well how can i fix that?
Old Jan 13, 2008 | 05:45 PM
theres a write up in the diy section:
https://www.hondaaccordforum.com/m_16994/tm.htm
let me know if you want pictures and stuff to help you visualize it.
Old Jan 14, 2008 | 04:23 PM
co1388
pics would help thanks
Old Jan 14, 2008 | 08:51 PM
http://www.verzend.be/v/4055937/pics.rar.html
you can see the upper seals in one of the pdf files. the lower seals are below the rocker arm assembly. in the pic where you see the rocker arm assembly removed from the head you see the spark plug tubes - they rest on those flats.
esan805
Mar 29, 2012 02:33 PM
mamtsberg
Mar 17, 2010 09:15 PM
typemodulo
Feb 1, 2007 02:32 AM
KimberlyC
Apr 16, 2006 11:51 AM
