Sponsored by:
Sponsored by:
91 Accord LX Auto
Old 11-18-2013, 10:27 AM
lindburgh's Avatar
Default 91 Accord LX Auto
hey guys i'm new here so i don't know how to post so i'm jus replying here to post.... ok my problem is my 1990 honda accord dx wont start early in the morning when it's cold, it will start after the sun comes out.... i changed the main relay but it still do the same thing..... i think its a weather issue. any help plz????
Old 11-18-2013, 11:20 AM
When you make first attempt to start in morning, turn keyswitch to On and listen for fuel pump. It should come on for 2-3 secs and go off at same time, Check Engine Light goes off. Radio and fan off to listen carefully for fuel pump in fuel tank.
If you don't hear the fuel pump, then either ignition switch problem or faulty fuel pump are likely.
If you hear fuel pump, then ignition fault is likely; coil, or ignitor. Check Honda Acura Starting Problems Repair Guide, Main Relay Locations for additional guidance.
Alternatively or to confirm ignition or fuel, a start test when no-start condition is present, is to spray 5-10 secs of throttle body cleaner or starter fluid into air intake at air filter housing. If car starts briefly, then ignition is good and fuel delivery is problem (fuel pump or main fuel relay). If car fails to start, coil or ignitor are likely.
Read posting rules/procedures and don't append a new problem to an old thread.
Old 11-18-2013, 07:36 PM
Please check for codes in the ECU/TCU......something like a code 6 would explain this......but you need to check/
SwitchUps
10-21-2010 05:37 PM
dejavu247
12-04-2006 07:50 PM
mnvikings1973
10-25-2005 01:58 PM
mnvikings1973
04-11-2005 05:42 PM
cpowers
04-03-2005 10:19 PM
Quick Reply: 91 Accord LX Auto
