91 accord trans
Old Sep 18, 2008 | 12:43 AM
bbobb
Default 91 accord trans
i have a 91 accord lx. recently the trans wouldnt go into convertor lockup. now the trans light blinks after driving for a bit. when it gets warmer the engine light comes on. some times it hunts between 3rd and 4th gears whe coasting. the speedometer also wont work. i got a 17 code from the engine light and a 4 code from the trans light. i am suspecting the vehicle speed sensor. how can i test it? also after driving for about 45 minutes in 84 degree weather, i shut it off then restart and drive. it works just fine. whats going on in there?
Old Sep 18, 2008 | 02:05 AM
Default RE: 91 accord trans
you can download a 91 shop manual from the online manuals thread in the DIY section. Both codes point to a bad VSS along with the symptoms. That shop manual will have the installation instructions too.
For testing you will likely need a volt meter and some back probing will be involved. There should be three wires. Use the volt meter to test for 5V and continuity to ground (likely black wire).
The VSS are known to go bad, so replacing it will likely solve your problem.
Good luck.
Old Sep 18, 2008 | 11:58 AM
A new VSS is very inexpensive, and available online extensively or on ebay (<$25 bucks for my last VSS).
Old Sep 27, 2008 | 02:05 AM
bbobb
idk about that price, around here they want about $200ish.
Old Sep 27, 2008 | 08:15 AM
Check ebay for "accord VSS". Yes, a new OEM VSS from Honda and installed by a Honda shop would be about $200.
Old Sep 27, 2008 | 11:16 AM
bbobb
no i mean 200 in my hand.
BLAS0827
Jan 9, 2007 12:11 AM
bmarshall
Jan 3, 2007 08:54 PM
Mohlmann
Jun 22, 2006 12:33 PM
mbo1985
Mar 25, 2006 04:07 PM
