'91 Accord0---Check Engine Light On/Rough Idle
Old May 22, 2006 | 02:05 PM
cwalti's Avatar
Default RE: '91 Accord0---Check Engine Light On/Rough Idle
After my distributer failed I had similar symptoms on my '91 LX after about 6 month. I Pulled the codes and it indicated a temp sensor. Turns out the jerk of a mechanic had clipped the locking feature on the sensor underneath the distributor. It is hard to find and impossible to see. (I think he set me up for return business...) I pushed it back in and the car ran like new. Before it ran so bad that I wanted to shoot the car. Idle only and stumbling upon takeoff. It would run perfect once under way. I did get another plug socket from a salvage yard and soldered it on to the harness, and all was well...
Old May 23, 2006 | 01:57 AM
lightshow's Avatar
dude you have desert honda on the case. you should do what he has advised and you can have a top tech give you advice on your problem for free. get that code
Kpick
May 5, 2015 08:51 PM
HondaJess
Apr 20, 2013 09:14 AM
HatchJunki
Mar 9, 2013 08:23 AM
Feb 13, 2007 09:30 PM
