91 Honda Accord Surging at Crusing Speed
Old Nov 1, 2015 | 11:33 AM
m2182's Avatar
Default 91 Honda Accord Surging at Crusing Speed
Hi,
I have a 91 Honda Accord EX, with automatic trans, it recently has had the O2 sensor replaced and now when I'm driving on the freeway at about 60-70 mph the car surges about +/- 100 rpms you can feel it and see the tach respond the same any help here would be great.
Old Nov 1, 2015 | 11:06 PM
Check for engine and transmission codes. There are some transmission codes that will not cause the S light or D4 light to flash. Find the link for checking engine code in the common diy thread on top of the gen tech help forum.
Check the fluid level in the transmission. Also, when was the last time the fluid was changed?
Old Nov 2, 2015 | 11:32 AM
shipo's Avatar
Is this on flat ground or in a hilly region?
Old Nov 12, 2015 | 10:36 AM
m2182's Avatar
The trans fluid is at correct level, and was changed about 800 miles ago, the car surges on hills or flat ground
RivCoRider
Mar 13, 2014 09:54 AM
iYuP
Aug 28, 2011 02:48 AM
stewart609
Mar 25, 2008 07:02 PM
rbwdriven
Feb 4, 2008 09:01 AM
aboutblank29
Nov 16, 2007 01:47 AM
