91: timing belt inspection
Old Feb 6, 2009 | 08:07 AM
jackfast's Avatar
Default 91: timing belt inspection
how in the world do you get the timing belt cover off for a visual inspection?
mine is held on by two 10mm bolts; the right hand one is accessible, the left is not.
is there a trick to it?
do i need to remove another part to get access?
is this a job for a pro instead of me?
Old Feb 6, 2009 | 08:42 AM
It's just recessed, so you probably have to get a skinnier socket?
Old Feb 6, 2009 | 08:47 AM
The valve cover traps the upper timing belt cover. It must be removed to lift the upper timing belt cover. The bolts are accessible w/ socket and short extension. A 1/4" ratchet and 10mm socket may help.
If you need more room from the engine mount, you can remove the mount while supporting the engine w/ a jack under the oil pan. Use a board to spread jack load. Manual does not mention this as necessary to remove upper timing belt cover.
Inspection of timing marks will require turning the engine w/ the crankshaft pulley bolt through the opening in the wheel liner. Timing mark on flywheel is under rubber boot on front of engine. Inspection of a timing belt for wear is not practical and does not give an indication of a "worn belt". A belt could look fine and break due to brittle nature of material (aging and heat).
Old Feb 6, 2009 | 03:14 PM
jackfast's Avatar
thanks to both responses.
i think it best for a pro to take a look...
Old Feb 6, 2009 | 08:47 PM
hondadude's Avatar
Well I know what a bad T-belt looks like.
If the teeth have any cracking at the base, replace the belt.
With the top cover removed you can shine a strong flashlight into the lower cover and look at the inside of the T-belt where it goes around the tensioner.
Attached Thumbnails 91: timing belt inspection-tbeltcrckib9.jpg
Tony1M
Apr 1, 2007 05:42 PM
tiger94
Mar 31, 2007 09:55 AM
maro
Dec 19, 2006 01:25 PM
tibbo
Jul 25, 2006 04:37 PM
hawzmolly
Nov 9, 2005 04:19 AM
