92 accord high idle reving up and down
Old May 1, 2011 | 03:57 PM
dixiechamp's Avatar
Originally Posted by sljones2
x2! i just finished a timing belt replacement and had pulled the distributor too so i was so worried when it was acting up. however, my google search revealed this thread and i tried it and it worked, so to PAhonda, thank you very much!
sorry for reviving this old thread but i am so grateful for the advice!
Ditto!!!! Was having the same issue, sure did not think it was because coolant was low but I checked and it was just above the cores. Filled it up and bled the air (wasn't much) and presto! problem solved. This is a great forum!
Old May 13, 2013 | 03:43 PM
mulehouse78's Avatar
Originally Posted by PAhonda
I would reset the ECU (pull the 7.5 Radio/Backup fuse in engine bay fuse box for a minute).
Air contacting the engine coolant sensor will also cause the ECU the misadjust the idle. When you refilled the coolant, did you bleed all the air out of the system? You loosen the bleeder on the thermostat housing until only coolant comes out while topping off the radiator.
Did you have the cylinder head repaired and planed at a machine shop? A broken timing belt will cause the valves to get bent.
How do you bleed the air out? i have this same exact problem
Old May 13, 2013 | 08:08 PM
Open the bleed screw on the thermostat housing & let the air out. The 2 places where air can collect are the T-stat and the radiator cap.
jtimcort
Mar 14, 2013 07:35 AM
MICHOASTYLE
Mar 15, 2012 06:16 PM
fusionstar
Jul 6, 2009 02:46 AM
mck52689
Jul 17, 2007 02:42 PM
Joshporsche
Jun 14, 2006 10:07 PM
