94 accord coolent in transaxle
Old Aug 23, 2008 | 08:30 PM
pdxcrx's Avatar
Default RE: 94 accord coolent in transaxle
thx texashonda for your reply, its really not to bad, like i said i got the car for free. the owner was letting it go bc he said the tranny was going out and it was about 15 minutes away from being impounded. original plan was to part it out and make a few bucks, but like i said it drives nice and is comfy.
by the way it has 202,000 miles on it, but it is in still real good condition.
Old Aug 23, 2008 | 08:35 PM
pdxcrx's Avatar
btw, being a honda guy, i have allready ordered the timing belt, water pump, and tensioners.
it does need a windshield and left rear glass ($400 installed).
i have found a bunch of service records in the car, but who knows. we can probably close out this forum, as i will go ahead and change out the transaxle.
anyway, thanks for your imput, i really appreciate it.
thanks agian,
jon
Old Aug 24, 2008 | 01:30 AM
evilash05's Avatar
ORIGINAL: pdxcrx
i put the fuild in the rad, from there it seaps into the transaxles.
This concerns me a little, did you put ATF-z1 in your radiator cap? Or did you put ATF in the tranny? ATF in no way goes from the radiator to the transmission, they are 2 seperate cooling units built into one device, in no way do they exchange fluids or come in contact with each other except for the fact that the outside casing is molded around the 2.
What you should do is take it to a mechanic and have them exchange the fluids in your tranny to ATF-Z1 do not use multi or dex fluids. Then I suggest you flush and fill your radiator, because your scareing me a little bit hah.
Also when adding tranny fluid you should switch through the gears in order to let the fluid exchange then check in park, with the engine running.
Old Aug 24, 2008 | 02:37 AM
pdxcrx's Avatar
no i did not put atf in the rad lol. i put it the filler hole of the tranny. i know it sound funny, but from what i understand from the manual i was reading (haynes) is that myradiator has a tranny cooler within it. it doesn't sound right to me either, but thats what i read. and somehow within the rad, there is a leak thatallows the coolent to mix with the tranny fuild (and leave to honda to come up with something like this, after they do use an inference engine).
Old Aug 24, 2008 | 08:12 AM
brayner's Avatar
the transmission fluid thru the radiator to cool i is pretty standard on all cars and trucks.
the best engines seem to be interference engines.
Old Aug 24, 2008 | 04:53 PM
evilash05's Avatar
ohh okay pdxcrx now I understand!
so basically what happened is the radiator was eaten away by corrosion of some sort and it went through the rad and the tranny cooler... So you should replace the rad, and then you need to flush both systems...
Thank god this problem was solved lol, but you may have long lasting effects of the tranny going, you may want to start looking at junkyards for a new one.
Old Aug 24, 2008 | 08:23 PM
  #17
pdxcrx's Avatar
glad we cleared that up, yeah i allready found one on craigslist for $150, it was still in the car so i got to try it out, now the guy is pulling it for me.
anyway, thanks texashonda and evilash05 for your comments.
67electro
Jul 12, 2013 05:08 PM
01HondaAccord
Jun 2, 2008 09:47 AM
92halx
Jan 12, 2007 12:07 AM
92halx
Jan 7, 2007 12:07 AM
joshuaaaronalpert
May 31, 2005 07:05 PM
