94 accord water leak
Old Oct 26, 2009 | 08:42 PM
ali300
Default 94 accord water leak
hello everybody,
today I wa s driving normally to my work.While driving I noticed that the temp is increasing.I turned of the car and I returned it back home.I raise the car up to check from where the leak is coming.It was leaking under the timing belt from small hole I think.pls see the pic attached below.
Old Oct 27, 2009 | 02:08 AM
That location is the weep hole for the water pump.
If you are going in to replace the water pump, the timing belt should also be changed.
Old Oct 27, 2009 | 08:28 PM
kris_loehr's Avatar
Is that your engine it looks like it has been sitting for awhile? The water pump is usually replaced with the timing belt.
IMTHEPUNISHER
Apr 4, 2012 05:40 PM
Honda Enthusiast
Feb 15, 2011 08:43 PM
demetrius
Feb 1, 2010 11:32 AM
pschoggens
Nov 6, 2007 02:36 PM
jcharvolin
Sep 26, 2005 05:53 PM
