95 Accord starts but immediately dies... help!
Old Aug 26, 2011 | 01:49 AM
twisted95accord's Avatar
Default 95 Accord starts but immediately dies... help!
I have a 95 accord v6 automatic. havent had too many problems with it. now it will turn over and start for a split second and then it dies. i don't even know where to start to find the problem with it. a guy i work with thought it could be the neutral saftey switch.. but i really wouldn't know..
any info would help..
thanks
Old Aug 26, 2011 | 06:45 AM
Tek310's Avatar
If it was the neutral safety switch it would start at all.
Do you hear your fuel pump prime in the "II" position?
Any check engine lights?
Sounds like a fuel problem if it starts then dies.
Old Aug 26, 2011 | 06:39 PM
Does it seem to die just as you let go of the key?
Kind of sounds like a bad key switch. Key in the on/pos II, can you check for 12v on the BLK/YEL wire at the dist?
Old Aug 26, 2011 | 11:01 PM
ya the fuel pump primes..you can hear it plane as day when you turn the key to II. no check engine light..
Old Aug 26, 2011 | 11:05 PM
ya as soon as you think its gonna start and run and let go of the key it dies.. i actually was messin earlier and if you hold the key to where the starter is keeping the motor turnin over it runs.. what does it mean if there is no juice to the blk/yel wire.. i just got off work so i will have to check it in the morning..
could it be anything to do with the distributor? my grandpa said it sounds like it could be gettin moisture in the distributor or something..
Old Aug 27, 2011 | 06:02 AM
I'm betting the electrical part of the key switch, kind of common. You can test the output at the key switch.
Old Aug 29, 2011 | 12:47 AM
i will have to check it out on my next day off.. thanks for helpin!
Old Aug 29, 2011 | 06:01 PM
My pleasure.....I'm 99% sure it is the switch, just always want to test before replacing.....no power to the BLK/YEL at the dist, the key switch isn't "sending" power, or a broken wire.
Good luck, let us know how it goes.
tater1972
Jan 18, 2020 01:16 AM
montag
Oct 5, 2017 05:49 PM
98v6accord
Mar 9, 2014 10:55 AM
trukid21
Jun 6, 2012 10:39 PM
dmatt40
Dec 21, 2009 07:07 AM
