'95 low beams
Old Jul 27, 2013 | 05:00 PM
Wido's Avatar
Default '95 low beams
Hi All,
I've tried to replace my low lights, both of blew up (in different times, fuses are fine). The problem is that I can't remove the bulbs from the headlights,
Is there anything else, beside 'twisting' the bulbs? I've seent there is an 'open-lock' sign, and I've followed that, but still haven't been able to remove the bubls.
Worst is, I've tried to use some pump pliers (is that the english name?) in one of the bulbs, and I broke all the plastic, so I have the sense that I'll have to remove the whole headlight just to get to the bulb and take it out.
I've seen this video
and looks like taking the headlight out is a looooot of hassle (compared with just removing the bulb)
cheers
Old Jul 27, 2013 | 07:30 PM
Did you break the plastic on the bulb, or did you break the ring on the headlight?
All you have to do is unplug the electrical connector from the bulb. Twist the plastic ring on the headlight to unlock the bulb. This just aligns the notches so the bulb can slide out. Installation is reverse.
If that plastic ring will not turn, use some WD-40. I remember mine was stuck and that helped.
Old Jul 27, 2013 | 09:16 PM
Wido's Avatar
Hi PA,
'Luckily', I just broke the bulb plastic, the headlight is fine. I didn't wanted to use WD40 because I was concerned about the oil in the headlight, what could happen with the heat in there.
I'll try again tomorrow (it's almost midnight where I am), and let you know how it goes. Thanks!!
Old Jul 28, 2013 | 12:58 AM
Let us know if you get er done and if you had any more problems.
otrawj
Feb 27, 2014 03:50 PM
ThavionHawk
Nov 16, 2008 02:38 PM
RondaTheHonda
May 3, 2008 11:14 AM
03EXCoupeBoston
Oct 3, 2007 08:03 AM
jasoncook3
Dec 28, 2005 10:10 PM
