96´ Accord A/T sometimes won´t shift
Old Mar 31, 2011 | 02:42 AM
pirulino23's Avatar
Default 96´ Accord A/T sometimes won´t shift
Hi!
My car has been having this issue ramdomly, most of the time the car runs great no issues, but once in a while, if I stop, and then run again, on a red light, the car won´t go further 20mph for like 30 seconds or if I accelerate up to, like 4000rpm, finally it shifts from 1st to 2nd and starts running as it should. What could be the cause of this, I already checked the a/t oil and it seems to be ok? is there a somewhat easy fix or we are talking major bucks?
Thnaks in advance!
Old Mar 31, 2011 | 11:57 AM
Does the D4 light start flashing when you are having problems? Have you checked for error codes? See How to get CEL codes in the DIY section. The OBD1 way will work for your car as well.
When did you last change the transmission fluid?
Old Apr 1, 2011 | 03:00 PM
pirulino23's Avatar
Actually the light is not on at all, it just won´t come up. Ill check for the codes at this moment to see what comes up
Thanks!
letsclique
Jun 18, 2016 04:29 PM
longdistance
Nov 11, 2009 09:37 AM
bobbobobbo
Dec 26, 2008 12:15 AM
cuatro201821
Apr 1, 2008 09:06 AM
egonzal24
Jan 3, 2008 06:46 PM
