96 accord lx FAN question
Old Jul 10, 2006 | 07:07 PM
isuboy's Avatar
Default 96 accord lx FAN question
we just installed a new raditor like 2 houra ago
there are 2 fans right
left one runs fine
but the right one i havent seen it running yet .......even i turn the heater and ac on
is this normal?
CANANYONE EXPLAIN IT TO ME WHAT FAN DOES WHAT ?
OK THANKS
Old Jul 11, 2006 | 01:44 AM
YeuEmMaiMai's Avatar
Default RE: 96 accord lx FAN question
check your connections to the fan that isn't running. IF you swap the connectors around and the fan runs, check the relay by swapping them. If the fan runs after swapping relay, replace it. If not, you need to check for power at the proper wires and that is something Desert Honda can help you with.
Old Jul 11, 2006 | 11:47 PM
deserthonda's Avatar
did you plug it in ?? the plug is below the coolant overflow bottle.........was it working before ??
Old Jul 11, 2006 | 11:49 PM
isuboy's Avatar
yes we plugged it rigght ...we made sure also that color of wires matches too ......oone black and one blue i think
and it was working before fine
Old Jul 12, 2006 | 03:22 AM
by the rt side you mean the fan on the passenger side correct ??
chk the fuse,,fuse # 21 20 amps underhood fuse box ,,,,,,,,,,,chk the relay,,, located in the underhood fuse box ,,,,,,chk to see if you are getting power and ground at the fan plug .. with car running a/c on, you should have power at the blue wire and ground at the black wire .. if you got both and motor does not run you got a bad motor ..
quick test ... start car, put A/c on, hit the back side of the fan with a big screwdriver a few times,, if it comes on. you got a bad motor
CDJDM07
Aug 24, 2011 09:51 AM
BOBBY-25
Jun 5, 2011 02:40 PM
ramachan9
Jul 11, 2009 11:57 PM
Equalizer
Feb 20, 2007 08:57 PM
daddy
Feb 6, 2006 02:52 AM
