96 accord lx FAN question
we just installed a new raditor like 2 houra ago
there are 2 fans right
left one runs fine
but the right one i havent seen it running yet .......even i turn the heater and ac on
is this normal?
CANANYONE EXPLAIN IT TO ME WHAT FAN DOES WHAT ?
OK THANKS
left one runs fine
is this normal?
OK THANKS
check your connections to the fan that isn't running. IF you swap the connectors around and the fan runs, check the relay by swapping them. If the fan runs after swapping relay, replace it. If not, you need to check for power at the proper wires and that is something Desert Honda can help you with.
by the rt side you mean the fan on the passenger side correct ??
chk the fuse,,fuse # 21 20 amps underhood fuse box ,,,,,,,,,,,chk the relay,,, located in the underhood fuse box ,,,,,,chk to see if you are getting power and ground at the fan plug .. with car running a/c on, you should have power at the blue wire and ground at the black wire .. if you got both and motor does not run you got a bad motor ..
quick test ... start car, put A/c on, hit the back side of the fan with a big screwdriver a few times,, if it comes on. you got a bad motor
CDJDM07
Aug 24, 2011 09:51 AM
BOBBY-25
Jun 5, 2011 02:40 PM
