96Accord Ex Manual trans. Starter will not activate
Old Sep 17, 2022 | 03:54 PM
Drivingmecrazy2's Avatar
Default 96Accord Ex Manual trans. Starter will not activate
Have replaced the starter (2 X), ignition switch, both clutch pedal switches, battery, ground wire. Still will not activate the starter. Runs if compression started.
Old Sep 17, 2022 | 08:56 PM
Verify the small blk/wht wire connected to the starter has 12V when you turn the key to the start position.
On the clutch pedal switch (I believe the lower switch) there should be a grey and black wire. Check that the grey wire has 12V when the key is in the start position.
Chezzie Massey
Nov 6, 2018 03:49 PM
neuhnda
Sep 23, 2014 10:27 AM
steak2286
Jan 9, 2012 07:05 PM
cinobyte
Nov 16, 2011 05:23 AM
brittanym06
Aug 1, 2007 09:58 AM
