97 EX piston damage
Old Feb 29, 2016 | 09:58 PM
wattsk69's Avatar
Default 97 EX piston damage
Bought a 97 5 speed for 600 bucks. Ran great. Drove it for a few days and decided to start fixing leaks. Previous owner said it had been eating small amounts of antifreeze lately. Decided to do a compression test to get a baseline. Cylinder 1 had 175 psi. 2 had a helicoil come out intact on plug, no test. 3 plug came out ok. Threaded gauge in. Turned over engine, gauge blows out into garage. I look inside and can see metal on top of piston. Long story short, pulled the head. Here are pics of metal and of piston. I have a new head on order. What will be my end result if I run it with some gouging on piston top? It's not severe but it is there. If you run your finger over it you can feel it slightly. Worried!
Old Mar 1, 2016 | 07:47 AM
shipo's Avatar
I'd be tempted to slap the new head on there and drive it until the motor quits.
Old Mar 1, 2016 | 08:20 AM
Dr. Drivability's Avatar
It will be fine, just clean the tops of the pistons up with some scotch brite pads.
Old Mar 1, 2016 | 05:50 PM
wattsk69's Avatar
Thank you both, new head will arrive Thursday and I will proceed with the reheading!! I cleaned tops tonite.
Old Mar 12, 2016 | 05:53 PM
wattsk69's Avatar
Head arrived and Imwas successful thanks to all your help!!! I appreciate all feedback received!
cbr10rr6
Jul 12, 2012 07:59 PM
rodmathews
Aug 5, 2007 10:49 PM
RSM93HONDA
Jul 17, 2007 07:31 PM
95SiR
May 22, 2006 03:45 PM
