98 accord Combination Switch Replace
Old Feb 5, 2013 | 03:51 PM
outta-line's Avatar
Default 98 accord Combination Switch Replace
Hi, 98 Accord exl Coupe v-6 with Sunroof. No Navi.
I pulled the steering wheel and the both combination switches and replaced them. Question is that even though I took pics before removing any wires, I have a red one from the airbag(I assume is the horn) and a brown tan wire that BOTH go back under the steering wheel. I can’t remember where they connect to and the factory service manual does not show the location either. this is a stock application with no mods. Ant idea on those 2 wire conections?
Old Feb 5, 2013 | 05:37 PM
There is a Red wire that should go to the horn.
For brown tan wire, what type of connector is at the end of the wire? Also, what color connector, if it is a plug instead of a terminal type connector.
Can you post some pics?
From what I can remember, I don't believe pulling the steering wheel was necessary to replace the combination switches?
Old Feb 5, 2013 | 06:03 PM
outta-line's Avatar
Default Wire Question
Red wire went to the brown after it looped behind steering wheel.
You have to pull the steering wheel as the combination switches have to screws that go through the plate that the cable reel goes on. I dont see how you could get them out anyother way. It is all back together and the girlfriend can go places again......
Dead Zeppelin
Jul 13, 2012 08:36 PM
pirulino23
Nov 12, 2011 06:34 PM
PAhonda
Sep 14, 2008 11:00 PM
mgabe2706
Dec 18, 2006 07:16 PM
Accordn2dis
Aug 26, 2006 09:36 PM
