98 accord trailer wiring
Old Dec 11, 2010 | 05:51 PM
bozos_si's Avatar
Default 98 accord trailer wiring
i put a hitch on my accord. anyone know where i can run the wiring thru the car? i just dont see anywhere. tried looking it up but cant find anything. if anyone has a diagram that would even be better.
thanks..
Old Dec 11, 2010 | 06:09 PM
It is located in the trunk, as shown in the owner's manual. See images.
It should be taped with blue tape to the wire harness.
Attached Thumbnails 98 accord trailer wiring-trailer-connector.jpg   98 accord trailer wiring-liner.jpg
Old Dec 11, 2010 | 06:37 PM
bozos_si's Avatar
yea. i got that. but what i am saying is where do i wire it to the hitch? there has to be an opening somewhere to get outside of the trunk area to bring the trailer wiring down by the hitch. right?
Old Dec 11, 2010 | 07:08 PM
Looks like people just run the wire out the trunk area and close the trunk on top of it when they are using it.
omninerd.com/articles/Install_a_Hitch_on_a_1999_Honda_Accord
etrailer.com/tv-wiring-install-2008-honda-crv.aspx
Old Dec 12, 2010 | 12:09 AM
bozos_si's Avatar
what the hell. there has to be a better way of doing it.
Old Dec 13, 2010 | 11:51 AM
bozos_si's Avatar
someone has to have put one in and figured out something so you dont have to let it hang out the trunk.
Old Dec 13, 2010 | 07:10 PM
On the 95, I just "ball" it up and tuck it to the left/drivers side, inside the trunk, when not in use. When we use the trailer, just connect and close the trunk on the wires....Orig owner towed a bass boat, so those wires have been thru heck-they do have split loom around them but still work 15 years later.....It only "hangs" out while towing, and while towing who can really see how or where the wires are?
Old Dec 13, 2010 | 08:18 PM
It's not like the trailer wiring gets crushed by the trunk lid, as the weatherstripping will just compress where the wire lays on it.
If you want, you can drill a hole at the bottom, insert a grommet in the drilled hole, and have a short run of wire and a connector outside. Then when you need to tow something, plug the external trailer wiring to the connector.
ProfPAS
Jun 19, 2014 08:31 AM
KD1977
Jan 6, 2012 10:15 AM
Rider1958
May 13, 2011 10:54 PM
JOwen2777
Apr 25, 2011 09:05 AM
honda97acc
Nov 21, 2010 01:08 PM
