98 Accord V6: code P0401
Old Oct 28, 2009 | 04:39 PM
boksh928
Default 98 Accord V6: code P0401
Hi
Got my engine check light on with code P0401 (EGR low emission). I researched and found it to be a known issue for this type of car. Can someone pls answer the following questions:
1. What harm could it do to my car if this is not taken care off? (I live in SC, so I don't have to pass a emission check)
2. Can someone share the service manual meant for this issue?
3. How can I fix it by myself?
-- Anas
Old Oct 28, 2009 | 06:13 PM
The EGR port is likely clogged. It can cause a slight stumble in the engine.
The repair is to remove off the intake manifold and clean out the blockage.
Google 99-085 honda service bulletin
The first link shows the procedure.
The pdf shows how to take off the intake manifold and how to install the kit. You can get away with just cleaning out the passage with a tube brush or using the 8mm bit in the instructions with carb cleaner, then reassemble.
Old Oct 29, 2009 | 11:14 AM
hondadude's Avatar
Old Oct 31, 2009 | 11:19 PM
boksh928
Thanks for your concern.
Honda won't sell the kit indicated in the service bulletin. So, I cleaned the EGR port with a drill bit and carbon cleaner. But I cracked the air intake tube which goes to the throttle body . The crack looks like this picture http://picasaweb.google.com/anas.eee...83230021202498. How can I repair this. can a replacement part be purchased for this? from where and how much is the price? what is it's function?
bjr001
Jul 14, 2013 07:12 PM
byebye2u
Dec 8, 2012 04:15 PM
lgnaclo
May 18, 2010 12:07 PM
SignetSilverAccord
Nov 3, 2009 06:49 AM
Tippman7641
Nov 5, 2008 01:21 PM
