'99 Accord ABS/brake sensor removal
Old May 21, 2012 | 10:32 PM
tobytigger's Avatar
Default '99 Accord ABS/brake sensor removal
Need help with details on how to remove ABS sensor on the front wheel hub removed on a '99 Accord sedan? There bolt is easy to remove but the sensor
looks like it needs a special tool to remove the ring on the backside?
Old May 21, 2012 | 11:19 PM
Dr. Drivability's Avatar
clear as mud?
Attached Thumbnails '99 Accord ABS/brake sensor removal-speed.jpg
Old May 21, 2012 | 11:29 PM
tobytigger's Avatar
Nice picture but doesn't answer my question.
Old May 22, 2012 | 08:26 AM
sensor should just pull out, might have to twist it a bit. why are you replacing? swapping out hub/knuckles?
Old May 22, 2012 | 04:18 PM
After that bolt is out, then the sensor is probably just stuck with corrosion. Soak with penetrating oil.
Have you got ABS error codes and checked whether it's actually a bad sensor?
pondrun
Nov 8, 2021 09:40 AM
93Accord2.2
Nov 7, 2013 07:10 AM
DOC2011
Mar 10, 2013 02:06 PM
blaze739
Feb 7, 2013 06:05 PM
kingkohlmn
Mar 6, 2011 08:13 AM
