99 Accord Air Conditioner Controls
Old Oct 18, 2011 | 10:02 PM
tlhiv's Avatar
Default 99 Accord Air Conditioner Controls
I have a friend that has a 99 Accord, and all of her lights on her A/C controls are on. She has the blower fan dial set to maximum speed, yet no air (cold or otherwise) is blowing out. She said she can barely feel outside air coming out (seemingly not from the blower but just from the car's speed forcing the air in).
She said that occasionally she can hit bumps or turn hard left and the fan will start blowing and cold air comes out. This seems to suggest a faulty connection somewhere, but I would appreciate any ideas that you might have on what might be causing this.
Thanks in advance!
Old Oct 18, 2011 | 10:21 PM
Refer to this thread. It could be a bad relay, blower motor,etc. Check by diagnosing and narrowing down where the problem it.
https://www.hondaaccordforum.com/for...esistor-43127/
Old Oct 18, 2011 | 10:41 PM
From the linked thread above, also check the power connector plug to see if it is loose, etc. The connector plug is referenced in that thread and the location shown in the video.
If the connector is okay, check for power going to the blower motor, if no power to motor then it may be the blower motor relay which is located in the under hood fuse/relay box. If power does go to motor and motor still doesn't run, then it may be the motor, such as worn out brushes, etc.
See attached image for relay location.
Attached Thumbnails 99 Accord Air Conditioner Controls-under-hood-fuse-box.jpg
meazz1
Dec 15, 2017 07:35 PM
jbraly
Sep 1, 2009 01:26 PM
tr7driver
Jul 8, 2008 08:19 AM
b4iloveu
Nov 23, 2006 02:10 PM
jeremiah6120
Apr 16, 2006 03:32 AM
