99 accord Ex Vtec sputters at 3900rpm
Old Jun 11, 2011 | 11:01 AM
mbrcic's Avatar
Default 99 accord Ex Vtec sputters at 3900rpm
My 99 accord ex with 4 cyl vtec engine has two problems. Engine cuts out at 3900 rpm no matter if parked or in drive. Also idle is real low especially with warm engine. Replaced with Junk Yard part what I thought was Vtec solenoid. Replacment was clean. Engine idles much better but still have cutting out at 3900 rpm.
Old Jun 11, 2011 | 11:04 AM
Check engine light is on? If yes, get codes and post them for help. Post the codes, not the interpretation.
Old Jun 11, 2011 | 11:49 AM
mbrcic's Avatar
Does anyone have any suggestions for this problem?
Old Jun 11, 2011 | 11:56 AM
Is the CEL on, are there any stored codes. Lots of ideas but if there are any codes that helps narrow down the possible answers.
Normal tune up items up to date (cap, rotor, check wires, plugs, ect). Oil in any of the spark plug tubes. Oil inside the dist.
PS. Please add your car info to your signature line.
Old Jun 11, 2011 | 01:03 PM
Tek310's Avatar
You have not give. Us much info to help you with.
Like two others have asked. Do you have a Check Engine Light on?
Old Jun 11, 2011 | 03:54 PM
mbrcic's Avatar
Error Code is P1259
Old Jun 11, 2011 | 04:00 PM
Tek310's Avatar
VTEC System Malfunction
Is that code definition.
Did you just replace the solenoid or the whole assembly? What about the switch connectors. Are they clean and intact? Take off the assembly from the head. There is a screen that can become clogged. Make sure it is not clogged.
Old Jun 11, 2011 | 04:07 PM
mbrcic's Avatar
Yes, Check engine light is on. Reset it and it comes right back on within a few seconds
Old Jun 11, 2011 | 05:39 PM
Check vtec solenoid connector and wire. On my 94 EX the wire separated from connector. I had to "hard wire" the female connector.
You can check the solenoid w/ a VOM. Resistance should be 14-30 ohms. If shorted or open, solenoid should be replaced.
95AccordDriver
May 28, 2012 07:36 AM
renzki
Oct 4, 2011 07:11 PM
bcnulater
Dec 8, 2010 03:22 AM
martymoatw/40'rope
Jul 30, 2009 09:45 PM
rwolfy
May 7, 2009 12:38 PM
