99 Accord horn is not working
Old Oct 23, 2011 | 01:03 PM
whiskerz's Avatar
Exclamation 99 Accord horn is not working
It blows when you hit the panic button . It has never blown when you hit the alarm but it stopped blowing when you hit the horn button . changed the relay no difference . fuses looked good. I am open to ideas , Thanks, whiskerz
Old Oct 24, 2011 | 05:49 PM
I'd check the ground connections to the horns fisrt.
Then, check the clock spring, any work done where the steering wheel would have to come off? Does the cruise controls on the wheel work.
Old Oct 24, 2011 | 06:34 PM
whiskerz's Avatar
steering wheel has not been off in a while. That I remember . It did get a new ignition switch a while back to cure the stalling issues . I think the cruise works , no power to the horns with the button pushed
Old Oct 24, 2011 | 10:11 PM
Ok, sounds (?) like the clock spring might not be the issue. PLEASE check the gound connections. Don't have a good manual for the 6th gens but know that Honda likes to use gounds to make things work.
The pic is for a 5th gen (94-97). Notice how when the horn relay closes, the ground is allowed to flow to the horn...WHT/YEL is hot at all times (from the under hood fuse panel) only when ground is applied to the horn (BLK coming into relay, then to horn thru BLU/RED) would the horn sound.
EDIT: of course if the clock spring/cable reel isn't grounding the "coil/magnet" side of the realy(LtGrn/Blu) then it wouldn't colse either.
Miss Frye
Jun 13, 2015 10:25 AM
ra1994gh
Dec 8, 2013 08:40 AM
decadude
Jan 15, 2011 03:23 AM
fireblast713
Nov 1, 2010 02:06 AM
Rob_KCMO
Apr 18, 2010 12:05 AM
