99 accord still skipping.
Old Aug 11, 2011 | 01:24 PM
accord99's Avatar
Default 99 accord still skipping.
My accord still skipping. 2.3 vtec. Tuned up, seafoamed, good compression. Pulled codes, po303, p1259, p1491. Any of these make start skipping little after warm up. Upper rpms skip not noticable. Help!
Old Aug 11, 2011 | 03:06 PM
p1491 is an EGR problem
p1259 is a problem with the vtec. Check the electrical connections for vtec solenoid corrosion. Check that your oil level is not low, because vtec runs off of oil pressure.
P0303 is a misfire in cylinder 3. When was the last time you changed your spark plugs?
I would start with p1491. You have to remove the upper part of the intake manifold. Fixing this could solve P0303.
P1259 is likely not related to the other two and can cause the car to run poorly too.
Old Aug 11, 2011 | 08:29 PM
accord99's Avatar
I have new ngk plat plugs, wires, cap and rotor. Is the vtec soli right there by the egr valve. It has a small leak around gasket where it mounts. I run mobil 1 run 5w30. Does the vtec soli have 3 square holes with one that has a screen over it. I have had it off and cleaned out with garb cleaner while back.
Old Aug 11, 2011 | 09:21 PM
That is the vtec solenoid. The oil leak could be dropping pressure as to cause a problem. I am not sure if carb cleaner could damage something inside.
accord99
May 15, 2012 06:23 PM
accord99
Feb 18, 2011 11:33 PM
cowsgonemadd3
Jun 16, 2010 11:33 PM
CedarCanoe
May 26, 2006 08:47 PM
erikhaha
Nov 20, 2005 02:48 AM
