99 accord tach broken
Old Feb 19, 2012 | 09:13 PM
Mchief's Avatar
Default 99 accord tach broken
My tach has been broken for a while. Everything else is running fine. Any suggestions on where to start to try and fix it?
Thank you.
99 accord ex 4 cylinder
Old Feb 20, 2012 | 06:54 AM
Earlier cars, the tach signal comes from the ignitor (in the distributor), but starting 1998 it comes from the PCM. So if the PCM isn't getting the proper signal from the engine sensors, it'll throw a CEL for those sensors. Are you getting a CEL?
If not, then you have to run down wiring issues between the PCM and the cluster. After ruling out bad wiring, I guess you're left with a bad tach.
speedracer92lx
Dec 11, 2008 06:33 PM
bushy74
Feb 28, 2007 07:06 PM
iridebmx33
Apr 6, 2006 01:41 AM
brownstreak
Jan 8, 2006 03:19 AM
badmrb
Dec 6, 2005 03:16 PM
