ABS bleeding
Old Jul 31, 2014 | 12:03 PM
Wrenching's Avatar
Default ABS bleeding
Bled both rear and front left brakes as part of changing out brake fluid. No problem. On RF bled and pedal goes to floor and won't pump back up. May have not have kept brake reservoir full enough. Air in ABS?? Question: what's going on here and how to fix.
Old Jul 31, 2014 | 12:22 PM
Try bleeding all the brakes. Follow the sequence: front left, front right, rear right, rear left.
Afterward, press the brake pedal several times to make sure the brakes work.
If it seems okay, also do a check for any leaks and test drive.
Old Aug 1, 2014 | 02:45 PM
Wrenching's Avatar
Thanks Redbull-1. Patience and your advice worked. Three trips around bleeding all four wheels did it. Air bubbles apparently far from calipers. Took about 1.3 quarts of fluid to flush and get all the air out.
Old Aug 1, 2014 | 06:13 PM
Glad you got it going....too many time these days in my life I'm left the just me and Newton for brake bleeding, that taks some time.
big boi
Jan 13, 2014 08:33 AM
93Accord2.2
Nov 7, 2013 07:10 AM
Pajamarama
Sep 1, 2012 03:21 PM
AngelFisher27
Jun 21, 2011 08:32 PM
LinX
Feb 27, 2006 04:01 AM
