AC Blower Problems!?!?!?
Old Aug 2, 2011 | 12:34 PM
jeffgp's Avatar
Default AC Blower Problems!?!?!?
I have a 2003 Accord 4 Dr Sedan 6Cyl. EXL AT
I have read other threads and from the beginning....
The blower had stopped working. I heard the AC click on, then turn right back off just as quickly. From reading the diagnosis sounded like the blower motor resister. I replaced the resister and sure enough the blower started working. I had cold air and it was working great. That was yesterday...
Today, as I started the car up I smelled burning electrical wire, and then noticed that the blower motor would not shut down. The motor will not stop even if I turn off the AC totally. Yes, when I shut down the ignition the blower does stop.
The air seems to be on high all the time and cools very well. Is my blower motor going out? I double checked and believe I have the correct resister.
Any help is greatly appreciated.
Thanks,
Jeff
Old Aug 2, 2011 | 01:08 PM
jeffgp's Avatar
UPDATE*
I ran a diagnostics check that I got from the DIY section. The code I get is "N".
Something is wrong with the blower motor circuit.
So, will replacing the blower motor fix this?
Is there a How to video for replacing like there is for the Resistor?
Jeff
Old Aug 2, 2011 | 01:26 PM
Did you solder in a resistor, or did you replace the whole part with a new one?
Old Aug 2, 2011 | 02:26 PM
jeffgp's Avatar
I replaced the Whole part. I have been told I may have gotten a bad part. They are swapping it out for me. So, I am about to go remove it, and take it in to swap. They said they'd have another around 2:55 CST.
Thanks for answering my post
Do you have any ideas?
Jeff
Old Aug 2, 2011 | 03:46 PM
That part controls the fan speed. The fan control on the HVAC or the wiring could be a problem. A volt meter should reveal if there is a problem with the wiring. You would need a shop manual and a list of the proper readings.
Old Aug 2, 2011 | 04:40 PM
jeffgp's Avatar
I replaced the part. The resistor I removed that I had purchased yesterday was burned inside. I detected a distinct burned odor. I replaced the old part with the one I just got today and everything works fine. I will continue to monitor it so I don't get stranded in 105 degree weather without ac.
Thanks,
Jeff
I will post with any follow ups ASAP
Old Aug 5, 2011 | 01:21 AM
jeffgp's Avatar
LOL...today I was driving in the Texas heat and my shifter **** fell apart. I drove straight to Honda when I got finished with work and bought a new part,,,another $$18.00. FIXED.
I want my new Toyota!
fcmiles
May 13, 2012 11:13 AM
Honda Man For Life
Apr 9, 2012 09:38 AM
nightowlll2010
Jun 26, 2011 02:29 PM
tara76034
Jul 15, 2007 09:41 AM
KimberlyC
Apr 16, 2006 11:51 AM
