Accord 1999, 4000 rpm idle,shifter whouldn't shift from parking (video)
Old Jul 21, 2014 | 03:26 PM
Airhead's Avatar
Default Accord 1999, 4000 rpm idle,shifter whouldn't shift from parking (video)
After changing raptured cooling house(heater house under distributor),car starts and rev's 4000rpm,wouldn't shift from parking.
Before I discovered raptured cooling house I was thinking problem was water pump because owner told me he smelled rubber so I was thinking timing belt slipped,and I din't even try to start the car,so I took of alternator and power-steering pump to look at the timing belt but it was ok so I put everything back together.
Checked all vacuum houses ok ,fuses ok ,compression good,got air out of cooling system,gas cable ok choke is fully closed,there is no check engine light,have spare hacked computer tried it, nothing helps
Please help
Old Jul 21, 2014 | 04:18 PM
The shift lock will prevent the car from being shifted out of Park if the throttle is open. The TPS will send a higher voltage signal to the PCM if the throttle is open, which in turn will prevent the shift lock solenoid from being energized to allow you to shift out of Park. Check to see why the throttle is open.
Did you purge all the air from the cooling system after the hose replacement?
Old Jul 21, 2014 | 04:32 PM
Airhead's Avatar
yes I did bleed the air out of the system,throttle is closed I disconnected cables to be sure.
Old Jul 21, 2014 | 04:35 PM
Airhead's Avatar
sorry was lying to you I disconected cables just now it's ok now
Old Jul 21, 2014 | 04:41 PM
Airhead's Avatar
Allso I disconected vacuum house from Idle control valve on the back of the throttle body so may be that was the reason,because I was holding throttle by hand before and it was closed.
Old Jul 21, 2014 | 04:42 PM
So, is everything is okay now?
Old Jul 21, 2014 | 04:55 PM
Airhead's Avatar
It's freaking cruise control cable!! I disconnected it works fine now.
Thanks everybody
Radfordicus
Feb 1, 2016 07:17 PM
Rilex
Sep 4, 2013 09:51 PM
james_nbdt
Feb 24, 2013 09:44 AM
slickwheel
Mar 1, 2008 11:11 AM
saad180
May 30, 2007 07:52 PM
